Data logger consumed from flowmeter
Good morning, I've connected a pulse counter from a volumetric meter to KepServerEX. In the Datalogger, I've set up data logging for the counter in SQL Server, and I would like to also include the average flow rate between two pulses. I'm having trouble finding solutions, do you have any ideas?
cmoreheadAnswer
@CL_9690815
These types of calculations are typically completed in a client application after the data is received from KEPServerEX.  It may be possible to leverage Kepware's Advanced Tags to potentially perform the calculations, Here is a link to the Advanced Tags product page:
Advanced Tags | Kepware | PTC
I recommend opening a support ticket with the Kepware team to have a pre-sales consultation to if a solution could work for you, Here is a link to the login page where a support ticket can be opened:
Log In | My Kepware
*Chris
cmorehead13-AquamarineAnswer
@CL_9690815
Log In | My Kepware
*Chris
