Data update slow over Modbus TCP ip
Hello all,
Recently I have configured 1 channels with 15 devices in that over modbus tcp/ip, which scan the data from fuji HMI. The hmi is programmed to send the data or parameter on every second to kepserver over Modbus tcp/ip,
The problem I am facing not regarding the connectivity  but the data is not updating on kepserver on every seconds. It gets refresh nearly after 30-40 seconds. Which is heading me in a problem from further scada system and its data logging. I am unable log the data at required interval.
Kindly suggest what can be the solution to get rid of the problem for this,
Reagrds
Bharat Vinchwekar
rajskumarAnswer
Please take a look at the following article as it may help resolve your issue:
https://www.ptc.com/en/support/article/CS292754
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
rajskumar16-PearlAnswer
