3-Newcomer
Derived Tag based on Boolean Values
I have multiple alarm tags in PLC.  I need to set an integer (long) value based on those tags such as
If tag1 = true then 1000 or if tag2 = true then 1005 or if tag3 = true then 1010
I can’t seem to figure out a formula that will let me do something like that.
MKhatriAnswer
Support
Hello
If you're looking to map multiple alarm tags to a single integer value, one option is to use an Advanced Tags Plug-in Calculation Tag in KEPServerEX. Create an expression that evaluates the alarm conditions in priority order and returns the corresponding value.
Example:-
IF(Tag1,1000,
IF(Tag2,1005,
IF(Tag3,1010,0)))
This would return:
  • Tag1 = TRUE → 1000
  • Tag2 = TRUE → 1005
  • Tag3 = TRUE → 1010
  • No alarms active → 0
Please try the above logic, It might works as expected.
Mohit
MKhatriCommunity ManagerAnswer
Support
Hello
Example:-
IF(Tag1,1000,
IF(Tag2,1005,
IF(Tag3,1010,0)))
This would return:
Mohit
