6-Contributor
DMG MORI Mitsubishi config
Has anyone configured a DMG Mori Machining center with a Mitsubishi controller?  I am hoping to see what is available...
cmoreheadAnswer
@MM_10545292
The DMG MORI document in the following link states their machines support OPC UA, MTConnect and MQTT.
Highest Level of Security IoTconnectorCompatible with Different Open Protocols Offered as Standard | News/topics | DMG MORI
I recommend utilizing OPC UA. You may need to consult DMG MORI support to see if the machines you have allows for these protocols.
*Chris
cmorehead13-AquamarineAnswer
@MM_10545292
*Chris
