Dynamic Tag via KepServerEX and OPCUA Server
I have a Chronos data logger in a machine that hosts an OPC-UA server.
KepserverEX6 now accesses this data logger.
The configuration is as follows:
Driver: OPC UA Client
Channel Name: 207050_DataLogger_Test2
Encryption: Basic256Sha256
Message Mode: Sign and Encrypt
Device Name: 0554
Now I added for Testing Pourpose a Tag:
Adress: ns=1;s=Logger.PT100.3
Data Type: Double
This is working fine with the Quick Client.
But what I realy want is a Dynamic Tag from a Python Programm:
That we do not need to add the Tag in Keyserver, but Easy get Access over the Kepserver OPCUA Client with tunneling.
why does the adress do not work?
ns=3;s=207050_DataLogger_Test2.0554.ns=1;s=Logger.PT100.3
The Error Mesage that i get is:
opcua.ua.uaerrors._auto.BadNodeIdUnknown: "The node id refers to a node that does not exist in the server address space."(BadNodeIdUnknown)
@TK_10809893,
My first thought is that the ns=3 needs to be changed to ns=2. Here is a link to the Kepware article that covers Dynamic Addressing through the OPC UA Client driver.:
Article - CS339970 - How to use dynamic addressing for OPC UA Client tags that point to a OPC DA datasource on the Server instance in PTC Kepware Products
If the numeric change does not resolve the issue, I recommend opening a support ticket with the Kepware team so a full analysis of your architecture can be had. Here is a link to the login page where a support ticket can be opened:
Log In | My Kepware
*Chris
