Error channel failed to connect
hello,
i'm a new user of thingworx plateform. I have ,no data on one of the machines so i checked the connection kepserver/client and there is this error : Channel failed to connect. | Status description = 'Could not establish a network connection to remote server.', Status code = 0X80AC0000.
Any ideas why this is happening and how to solve it ?
Many thanks
VladimirNAnswer
Take a look:
Bhupendra
Please check the following points -
  • Firewalls/Routers/Switches all have the correct rules to allow the requested port opened bi-directionally
  • Verify device at the target IP address can accept connections on the requested TCP port
  • Verify device at the target IP address is powered on, connected and available on the network
  • Check and install the latest windows updates on the host side if required
  • check the Test-NetConnection [host] -Port [port number]in powershell
  • Sometimes the target Windows OS may block the OPC UA Server Application after a power off and restart
    Allow the OPC UA Server Application
VladimirN24-Ruby IVAnswer
Take a look:
Emeritus
Hello @Lo_ry96,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
