Error when trying to activate the KepServer Licence
This is the message displayed when i try to import the response file from KepServer.
Failed to generate request :
[First (or only) signature invalid.]
Click OK to return to the wizard
Someone could help me ?
Thank you
Please follow below procedure for license activation and let us know.
  • Generate activation_request.txt
    • Save to local folder
  • Compress or Zip activation_request.txt file
  • Copy activation_request.txt file to external drive
  • Copy activation_request.txt file to machine with internet access
  • Unzip or extract activation_request.txt file
  • Login My Kepware portal upload activation_request.txt file
    • activation_response.txt file is generated
  • User must download activation_response.txt file
  • Compress or Zip activation_response.txt file
  • Copy activation_response.txt file to external drive
  • Copy activation_response.txt file to KEPServerEX machine
  • Unzip or extract activation_response.txt file
  • Import activation_response.txt via License Utility
BR
Hi thank you for your message.
I have already done that but still the same problem.
I have also do the recommendation here :
https://www.ptc.com/en/support/article/CS293892
Generally this issue occurs when activation_request.txt/activation_response.txt  file get corrupted while moving from one PC to another.
Have you compressed or zipped the files while moving from one PC to another ? If yes, I recommend opening a support ticket with the Kepware Technical Support team. Here is a link to the my kepware login page where a ticket can submitted:
https://my.kepware.com/s/login/
