Ethernet with LTAPP Protocol
Hi I've one lincoln electric(Arc Tracker) device which supports ethernet communication, which has LTAPP protocol for their application to talk over it.
How can i get those data in kepware using LTAPP?
Bhupendra
Hi
Kepware has some custom configurable drivers hence I would request you to share the data format of LTAPP protocol which can communicate over the Ethernet communication with the device(Arc Tracker).
Please connect with Kepware solution team to see if it worked
Solutions Consulting: presales.support@kepware.com
Thank you
