6-Contributor
Fanuc Focas DMG Mori
Has anyone been able to figure out the address for program header?
cmoreheadAnswer
@MM_10545292
The driver supports 'cnc_exeprgname_Name' which I believe you are referring to as the "program header". Please take a look at the knowledge base article in the following link which covers the addressing and KEPServedrEX versioning required to access the address.
Article - CS308349 - How to address the memory location containing the Fanuc Focas program information in PTC Kepware products
*Chris
cmorehead13-AquamarineAnswer
@MM_10545292
*Chris
