File transfer using kepware.
Is it possible to transfer a file using kepware to thingworx. we have a case where thingworx and file both are present in same network but thingworx is in cloud.
There are csv files that are written after a set of interval on a local computer. we need to use the same data for visualizing in a mashup.
You can't use Kepware to do a Transfert file to Thingworx. You can try to do with the EMS.
