Apr 3, 2024 4:55 AM UTC
How can i convert decimal value to ascii Character with kepwareEx Server?
Hi~ all.
I'm Kim.
I'm inquiring because there is a function I need while setting KepwareExServer up.
PLC only send string value by ascii code
(ASCII numbers to srting.)
for example value 65 to 'A' or 065066 to 'AB'
I would like to thank you in advance.
VladimirNAnswer
Apr 3, 2024 7:55 AM UTC
Take a look - "Is there a way to convert decimal data coming from a Siemens PLC to ASCII in Kepware/Thingworx": https://community.ptc.com/t5/Kepware/Is-there-a-way-to-convert-decimal-data-coming-from-a-Siemens-PLC/td-p/922210
VladimirN24-Ruby IVAnswer
Apr 4, 2024 4:52 AM UTC
Thank you for reply.
but i already tested above method. that is not what i want.
is there any method using advanced Tag function?
Advanced Tag > derrived tag > Function TAG(Simulator.Device1.Tag1)  is not convert Ascii decimal to ascii code convert function.
(Ex. 65 --> 'A')
Emeritus
Apr 10, 2024 4:56 AM UTC
Hello @SK_9135781,
It looks like you have some responses on your topic. If it helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
Support
Apr 16, 2024 6:45 PM UTC
Greetings,
Does this Post answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Mohit
