How Can I import 4000+ log items into Kepware V7 data logger?
I just installed V7 Data Logger and would like to be able to import 4,000+ log items.  The connectivity suite has export/import capabilities. I don't see it for Data Logger.  Is there a way to manipulate the log items via JSON, REST api, or other method?
MKhatriAnswer
Support
Greeting!
Yes — you can manipulate, import, or bulk‑create Data Logger log items in Kepware V7, but not from the Data Logger UI directly.
You must use the Kepware Configuration API (REST/JSON) or the CSV import/export scripts that PTC provides.
Mohit
Please take a look at the following article as it may help resolve your issue:
How to create data logger items via Configuration API in PTC Kepware Products
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials. Thanks
Thank you. I will.
Greg Franz
Phone 847-406-4700
Ext 2700
MKhatriCommunity ManagerAnswer
Support
Greeting!
Mohit
