How to config the tags to receive XML parameters in the OPC UA server?
the data to receive like:
<?xml version="1.0"?>
<MsiMessageContainer xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<messageInstanceId>8edad249-6f54-48b1-0e1k-38999clf08a3</messageInstanceId>
<direction>MES_TO_SF</direction>
<systemId>55</systemId>
<messageType>MsiOrder</messageType>
<messageContext>502</messageContext>
<message>
<MsiOrderParameterMessage>
<messageInstanceId>878af3de-m6e4-447a-a363-cd62b5ccf0ed</messageInstanceId>
<messageId>DOWNLOAD</messageId>
<supplierId>1</supplierId>
<creationTime>2023-02-21 09:21:05,115</creationTime>
<parameter>
<name>Line_2</name>
<dataType>String</dataType>
<value>11/2021</value>
<isQualifier>false</isQualifier>
<acquisitionTime>2023-02-21 09:20:10,668</acquisitionTime>
</parameter>
<parameter>
<name>Batch_Size</name>
<dataType>Long</dataType>
<value>100000</value>
</parameter>
<parameter>
<name>Line_1</name>
<value>06/2020</value>
<acquisitionTime>2023-02-21 09:20:10,638</acquisitionTime>
</parameter>
<parameter>
<name>EquipmentId</name>
<value>11</value>
<isQualifier>true</isQualifier>
</parameter>
</MsiOrderParameterMessage>
</message>
</MsiMessageContainer>
MRohillaAnswer
Support
Greetings!
You can use the XML Client Driver to pull in XML data into KEPServerEX then have an OPC UA Client read those tags. You can refer the below manual :
https://www.ptc.com/store/-/media/Kepware-Store/EN/2021/2021-opc-xml-da-client-manual-en.pdf
Mohit
MRohillaCommunity ManagerAnswer
Support
Greetings!
Mohit
