How to enable Automatic Tag Generation
In our project, we have planned to add lots of devices and also plan to add all the associated tags which would mean adding the tags 1 by 1. I was going through the automatic tag generation option but even after I click on 'Create tags' in 'Tag Generation' option, nothing happens. How do I enable this?
cmoreheadAnswer
@Devang_Singh
Not all drivers support Automatic Tag Generation (ATG). Here is a link to the Kepware knowledge article that covers the drivers that support ATG:
https://www.ptc.com/en/support/article/CS291820
If the driver supports ATG, there is no need to enable as it will work provided the connection to the device is Good and the demo timer hasn't expired for non-licensed instances.
*Chris
cmorehead13-AquamarineAnswer
@Devang_Singh
*Chris
Thanks Chris for sharing the list. Our manufactures are not in the list so it makes sense.
