How to read kepware tag values in thingworx ?
Hello all,
We want to read kepware/Thingworx Industrial Connectivity tag values in thingworx using services/programatically. Can any one help with this ?
Velkumar R
Hi Velkumar,
Wanted to clarify what you mean by read tags programtically.  Typically tags from Kepware are setup with a remote binding to a thingworx property to access the value.  So we can see available tags in the Thingworx platform but not pull values without that binding.
Is you configuration setup so that cannot work?  We can look at other options but it would be best to know you basic structure or use case.
Adam
