I am experiencing an issue seeing Variable data in the OPC Quick Client.
But in opc da i can able to import the tags after importing if i see the values of imported tags it showing unknown.
@GS_8739488,
The QuickClient makes an OPC DA connection. I am not sure I follow your described problem. The QuickClient also populates the tags directly from the KEPServerEX configuration. Can you please elaborate on the issue you have encountered. Are there any errors received?
*Chris
