IoT Gateway 500 Internal Server Error when using Basic Authentication method
I am trying to read a tag using IoT Gateway.
I am using POSTMAN as testing tool
GET http://143.28.91.145:39320/iotgateway/read?ids=LPDASTTT.UPack_To_FDM_Alex.PO_Download.Init.ProductID.DATA/8 with no authentication gives me proper result,
but
GET http://143.28.91.145:39320/iotgateway/read?ids=LPDASTTT.UPack_To_FDM_Alex.PO_Download.Init.ProductID.DATA/8 with basic authentication and username Administrator and password (my Administrator password for KepserverEX) returns 500 internal server error. The version of kepserver is 6.11
cmoreheadAnswer
@DD_10420206,
What version of JAVA are you using? I have seen in previous instances where newer versions of JAVA other than version 8 have yielded the exact error in which you have encountered in the same scenario.
*Chris
cmorehead13-AquamarineAnswer
@DD_10420206,
*Chris
Good guess, I solved it by installing other JRE. I was using Coretto JRE 8 which apparently didn't work with 6.11 - the curious thing is that it was working fine with older version. We can mark this as solved
