VladimirRosu_116627Answer
Hi
The My Kepware portal does not uses the same accounts as the eSupport portal, meaning that if you created an account in Support.ptc.com that will not work in the My Kepware portal.
You just need to create an account in the Kepware portal and after that you'll be able to activate your licenses etc.
