3-Newcomer
Jun 7, 2023 3:58 PM UTC
Kepserver 6.8 UA Server certificate loading error
Hello, is there a way to disable the certificate verification on startup for Kepserver 6.8 so that I will not get error message like this "The UA Server certificate is expired. Please use the OPC UA Configuration Manager to reissue ... "
MRohillaAnswer
Support
Jul 4, 2023 1:10 PM UTC
Greetings!
No, the certificate must be imported using the related GUI workflow.
Mohit
Jun 8, 2023 3:20 PM UTC
Article - "The UA Server Certificate has expired. Please use the OPC UA Configuration Manager to reissue the certificate in PTC Kepware Products": https://www.ptc.com/en/support/article/CS387585
3-Newcomer
Jun 8, 2023 4:31 PM UTC
Thanks.
Is there a way to do those steps programmatically ? Is there API to read the UA Server certificate expiration date ?
Support
Jun 12, 2023 3:37 PM UTC
Greetings!!
In the Windows product, no not currently. The end user can of course programmatically generate their own self-signed certificate using OpenSSL outside of Kepware but a couple of things:
1- if they want to use Kepware to generate their self-signed certificate, they must do this via the GUI in the Windows product currently.
2- if they decide to generate their self-signed certificate outside of Kepware, then they still need to use the Kepware GUI to import the new certificate.
Mohit
3-Newcomer
Jun 12, 2023 8:03 PM UTC
--> If I generate the self-signed certificate using OpenSSL, can I just copy that certificate to the path that Kepware stores them ?
MRohillaCommunity ManagerAnswer
Support
Greetings!
Mohit
Support
Jul 17, 2023 7:58 PM UTC
Greetings,
Since your question has been answered I have marked the appropriate response as the solution to your post. If you disagree with my choice please let me know.
Mohit
