KEPServerEX 6.14.263.0 was flagged by the security team for vulnerabilities
We installed KEPServerEX 6.14.263.0 on a customers VM last year and they now say it's getting flagged by their antivirus software. Not sure what they are using but wondering how often this happens and if installing the latest version will help?
cmoreheadAnswer
@Tanquen
Please take a look at the Kepware knowledge base article in the following link.   It shows the vulnerability you have mentioned was recognized and addressed in the latest release of KEPServerEX (v6.15)
Article - CS397286 - Security vulnerability identified in PTC Kepware Products - CVE-2023-3825
*Chris
I have zero idea if this is related - you would have to provide more details regarding exactly what CVE the AV is flagging, But I have an unrelated software package I have to update yearly that I can't download this year because Sophos AV targets the following GIF vulnerability contained in the package.
https://learn.microsoft.com/en-us/security-updates/SecurityBulletins/2013/ms13-056?redirectedfrom=MSDN
The odd part is that this vulnerability is from 2013 so why has it not been flagged by my AV till now?
No idea if this helps, but at least you are not alone 🙂
Tanquen12-AmethystAuthor
This is the vulnerability they flagged.
CVE-2023-3825 has been assigned to this vulnerability. A CVSS v3 base score of 7.5 has been assigned; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
Description
PTC’s KEPServerEX Versions 6.0 to 6.14.263 are vulnerable to being made to read a recursively defined object that leads to uncontrolled resource consumption. KEPServerEX uses OPC UA, a protocol which defines various object types that can be nested to create complex arrays. It does not implement a check to see if such an object is recursively defined, so an attack could send a maliciously created message that the decoder would try to decode until the stack overflowed and the device crashed.
cpe:2.3:a:kepware:kepserverex:*:*:*:*:*:*:*:*
Show Matching CPE(s) From (including)
6.0.0 Up to (including)
6.14.263
So maybe fixed in 6.15?
cmorehead13-AquamarineAnswer
@Tanquen
*Chris
