KEPServerEX 6.16, Can you generate tags for more than one device at a time?
Not a huge deal but after using the device discovery it would be nice to select 50 or 60 of the few hundred devices and have KEPServerEX do the tag generation on each vs going into the properties of each and then using the create tags option over and over.
aservetasAnswer
In the interim, you could use a client application to issue a write to the system tag for each device after they have all been discovered/imported into the project.
With the proper permissions enabled, you can write to this tag to start the tag generation process:
Channel1.Device1._System._AutoCreateTagDatabase
Modify the channel and device names according to your project specifically.
-Andy
Andy Servetas
Principal Technical Support Engineer | Kepware Technologies
@Tanquen
Here is a link to the Kepware knowledge article on how to open an Enhancement Request:
https://www.ptc.com/en/support/article/CS295047
*Chris
aservetas15-MoonstoneAnswer
-Andy
Andy Servetas
