KepserverEX - Advance tag Link tag is not write value to the compactlogic PLC
After communication fails and got resumes between Kepware and COMPACTLOGIC  PLC, but the link is not writing value to the PLC.
After disabling and enabling the link tag then it starts writing the value to plc . But it has to happen automatically without reenabling the link tag.
Please suggest a solution regarding this asap
Please take a look at the following article as it may help resolve your issue:
https://www.ptc.com/en/support/article/CS391203
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
