pshashipreetham
KepServerEx to OPC UA Client Connectors
Hi
Installed KepServerEX on the Azure VM, and KepServerEX is by default configured with an opc ua Configuration on local host, can this OPC UA Configuration of the KepServerEX can be Connected with the OPC UA Client Connectors ?
@paic @slangley @c_lowy
Shashi.
pshashipreetham
After lot of research and trials, made the Connection between KepSerEx (installed in Azure VM) and Tulip Connectors and also with the Prosys UA Client.
Attached the Configuration steps document.
Shashi.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
pshashipreetham
pshashipreetham19-TanzaniteAuthorAnswer
Shashi.
