KepserverEX v6 connection to Wago 750-362
We have a Wago 750-362 Fieldbus Coupler Modbus TCP device from an outside vendor that I would like to collect data from. We have the Manufacturing Suite and I see the Wago Ethernet and Modbus TCP drivers. It doesn't appear that the Wago driver supports this model, but I'm not familiar enough with protocols to determine if I can use the Modbus TCP driver. Is the Modbus driver an option, or would I have to reach out to the vendor to see if they'd replace the device with an ethernet model? I am anticipating that they will be resistant to the idea.
Thank you.
cmoreheadAnswer
@JN_9243123
Looking at the Wago document in the following link it appears as though the device only support Modbus TCP connections.
Fieldbus Coupler Modbus TCP (750-362) | WAGO USA
I would attempt to make the connection using the Kepware Modbus TCP/Ethernet driver and reach out to the Kepware through a support tick if additional assistance is needed. Here is a link to the login page where a ticket can be opened:
Home | My Kepware
*Chris
cmorehead13-AquamarineAnswer
@JN_9243123
Home | My Kepware
*Chris
