KEPServerEX6
Hello, We have a PC which is running KEPServer EX6, but having issues connecting to the OPC server date.
Errors I'm getting are as follows:
Date Time Level Source Event
11/12/2025 16:52:55 Error KEPServerEX\Runtime Attempt to add item 'Channel3.BottleMC3.Global.SCADA_CurrentHalfHour' failed.
ntripathiAnswer
Greetings @NQVC_290124,
I hope you're doing well.
Please take a look at the following article as it may help resolve your issue:
https://www.ptc.com/en/support/article/CS272971
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
ntripathi16-PearlAnswer
Emeritus
Hello @NQ_01_14434166,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
