Kepware Configuration API Datatypes Conversion
Hi all,
I have been experimenting with the Kepware Configuration API, specifically creating tags.
I see that the data types in the API (EX: "servermain.TAG_DATA_TYPE": 21) are integer form, but I am unable to find a table that shows which data type converts to which integer, and when I create a tag without putting in a data type in the content it doesn't seem to automatically get the correct data type.
Anyone know what integers correlate to which data types?
Thanks!
aservetasAnswer
Please see the reference code below:
        "symbolic_name": "servermain.TAG_DATA_TYPE",
        "display_name": "Data Type",
        "display_description": "Select the format of the incoming tag data.",
        "read_only": false,
        "type": "Enumeration",
        "default_value": -1,
        "enumeration": {
            "Default": -1,
            "String": 0,
            "Boolean": 1,
            "Char": 2,
            "Byte": 3,
            "Short": 4,
            "Word": 5,
            "Long": 6,
            "DWord": 7,
            "Float": 8,
            "Double": 9,
            "BCD": 10,
            "LBCD": 11,
            "Date": 12,
            "LLong": 13,
            "QWord": 14,
            "String Array": 20,
            "Boolean Array": 21,
            "Char Array": 22,
            "Byte Array": 23,
            "Short Array": 24,
            "Word Array": 25,
            "Long Array": 26,
            "DWord Array": 27,
            "Float Array": 28,
            "Double Array": 29,
            "BCD Array": 30,
            "LBCD Array": 31,
            "Date Array": 32,
            "LLong Array": 33,
            "QWord Array": 34
-Andy
Andy Servetas
Principal Technical Support Engineer | Kepware Technologies
aservetas15-MoonstoneAnswer
        "read_only": false,
        "enumeration": {
            "Default": -1,
            "String": 0,
            "Boolean": 1,
            "Char": 2,
            "Byte": 3,
            "Short": 4,
            "Word": 5,
            "Long": 6,
            "DWord": 7,
            "Float": 8,
            "Double": 9,
            "BCD": 10,
            "LBCD": 11,
            "Date": 12,
            "LLong": 13,
            "QWord": 14,
            "String Array": 20,
            "Char Array": 22,
            "Byte Array": 23,
            "Short Array": 24,
            "Word Array": 25,
            "Long Array": 26,
            "DWord Array": 27,
            "Float Array": 28,
            "Double Array": 29,
            "BCD Array": 30,
            "LBCD Array": 31,
            "Date Array": 32,
            "LLong Array": 33,
            "QWord Array": 34
-Andy
Andy Servetas
