Kepware execute tag from client/rest server
Dear community,
another very basic question from me;
if I want to "execute" a tag which basically just sends a hard coded string to an device; how do I do that from the client perspective?
I have configured an tag in UCON which sends a string. Furthermore I do not want to periodically send the string; only when the client application wants it.
I know I could get data from the client for this tag (for example a '01' ASCII string)  and could use IF-branching in UCON to execute the transmit command if the tag contains the data '01'.
But I think I have overlooked something; I feel like there should be a "right"/"easier" way to do that from the client application.
I have looked into the documentation but haven't found an satisfying answer yet; please help me.
Kind regards
Works if you transmit anything; question is misleading.
Kepware_User12-AmethystAuthorAnswer
