Kepware Export and Import Command
We would like to know the approach for automatic device tag Export and import functionality can be carried out.
What is the best approach/ solution using command line script or API method. Please share the details/ code
Support
Hi @RB_8755094.
Can you provide more information regarding the need for this?  Are you migrating?  We just need to make sure we're responding to your question correctly.
--Sharon
Currently in Kepware, user can manually go n select the project/device and then export or import function is available. I am looking forward through some script to automate these functionality.
