Dec 16, 2021 12:46 PM UTC
Kepware IoT Gateway Limitations
Hi there,
Is there any licensing or performance limitation regarding
  • the number of IoT Gateways agents running at the same time
  • the number of tags those IoT Gateways agents are reporting
Nahuel
Dec 17, 2021 1:27 PM UTC
 Hi Nahuel,
You can ask technical support, here: https://www.ptc.com/en/support/case-logger
Support
Dec 20, 2021 7:54 PM UTC
Hi @nahuel.
Please provide more information regarding the use case.  We're not sure what type of gateway product you're running.
--Sharon
nahuel14-AlexandriteAuthor
Dec 28, 2021 3:58 PM UTC
Hi @slangley!
I am using Kepware's built-in MQTT Client and the goal is to connect the MQTT client to some cloud provider (ex, Azure) using a one-to-one topology. That is, using one MQTT Client per Asset / PLC.
With that context in mind, I wanted to know the limitations stated in the first post.
FYI, this is my Kepware version
Regards!
Nahuel
