Kepware IoT Gateway - Tag ID Separator
Hi!
When a Tag is configured to be reported by the IoT Gateway, the Tag ID is automatically formatted following below convention:
  • <channel>.<device>.<tag>
Is it possible to change the dot separator for a dash one? So that the Tag ID looks like:
  • <channel>-<device>-<tag>
Nahuel
Hi @nahuel ,
As far as I know,
  • It is not part of current functionality.
  • However as a Workaround you may introduce a pre-processing step on the receiving side, that would prepare the messages as needed.
Regards
Bhawna
Hi @nahuel ,
As far as I know,
Regards
Bhawna
