9-Granite
Kepware licensing
Hi friends i need support to recuperate kepware licence that i have no acces more, to the machine originally installed. Need i open especial ticket to this resolution? Can you explain how i open this especial ticket?
Tks
Greetings,
In order for us to assist with that, you would need to submit a ticket through the My Kepware portal. You can select 'submit a support ticket' and it will be routed appropriately and we can assist.
Kind Regards,
Andrew Black
Senior Technical Support  Engineer
Greetings,
Kind Regards,
Andrew Black
Support
Hi @DiegoTavares.
Were you able to obtain support for your issues through a case?  If so, posting the solution here for other community members would be greatly appreciated.
--Sharon
9-Granite
@slangley  Thanks a lot, sorry about for long to answer.
hugs
Diego
