Kepware not able to connect to Azure Iot HUb
Getting below Error
  IoT Gateway                 Failed to connect to server: '127.0.0.1:57212'. Please verify this connection information is correct and that the host can be reached.
Hello Vladimir,
The issue was with Kepware version we were using 6.12 and after upgrading to 6.18 it got resolved
VV_924035912-AmethystAuthorAnswer
Hello Vladimir,
Glad you solved this problem.
