3-Newcomer
Kepware Server 7 and modbus ModRSsim2 simulator
Hi there,
I’m trying to set up a connection between Modbus TCP driver in Kepware Server 7 and modbus ModRSsim2 simulator.
Port 502 and device ID = 1 are used in both ends.
When Kepware starts, it shows the following line i log window:
   Channel1 | Starting unsolicited communication. | Protocol = 'TCP', Port = 502.
Should it be something like Modbus TCP Client/Master mode instead ?
In Kepware Server 7 where do you switch between Modbus TCP Client/Master mode and Modbus TCP Server/Slave/Unsolicited mode when you set up a channel ?
Any guidance would be greatly appreciated.
Thanks in advance,
Henrik
MKhatriAnswer
Support
Greeting  HC_14488809
  • The log message “Starting unsolicited communication” indicates Kepware is acting in Modbus TCP Server (Slave/Unsolicited) mode, not Client/Master.
  • In KEPServerEX v7, the mode is not a simple toggle—it depends on the driver selected while creating the channel:
    • Modbus TCP/IP Ethernet driver → works as Client/Master (polling mode)
    • Modbus TCP/IP Unsolicited Ethernet driver → works as Server/Slave (unsolicited mode)
  • To connect to ModRSsim2 (which is a Modbus TCP Server/Slave), Kepware must be configured as Client/Master.
  • Action:
    • Delete or modify the channel using “Modbus TCP/IP Ethernet” driver (not Unsolicited)
    • Configure:
      • IP: simulator IP
      • Port: 502
      • Device ID: 1
  • After correct setup, Kepware will poll registers instead of “unsolicited communication”.
3-Newcomer
Issue seems to be resolved now.
I tried to have Kepware and ModRSsim on different machines and that works.
Communication is fine and Kepware is no longer using unsolicited communication:
MODBUS_TCP_CHANNEL | All channels are subscribed to a virtual network or all devices are listening to remote addresses, stopping unsolicited communication.
MKhatriCommunity ManagerAnswer
Support
  • Action:
    • Configure:
      • IP: simulator IP
      • Port: 502
      • Device ID: 1
