Jun 17, 2026 7:08 AM UTC
Kepware Server 7 DCOM Issues With Windows Server 2025
I am using Kepware Server v7.0.236 with FTView v16 on Windows Server 2025 in a Domain setup.  The Kepware Server is installed on the same server as the FTView application.  I have a FTView Client PC (Windows 11 24H2) which runs the FTView client.  The problem is when I run the FTView client on the W11 PC any tags on a graphic which directly address the Kepware server don’t read.
I’ve gone through every step of the Kepware “Configuration Guide Remote OPC DA (DCOM)” and had a 2 hour Teams session with Kepware UK Tech support (MAC Solutions) while I’ve had remote desktop connection to the server. We went through the settings on both the Server and Client step by step and confirmed the recommended settings were in place and even uninstalled/reinstalled Kepware but nothing has worked.
Anyone had similar issues and found solutions ?
MRohillaAnswer
Support
Jul 1, 2026 11:54 AM UTC
Greetings ​@PL_9524549,
Please review the referenced knowledge base article and proceed with configuring the DCOM security settings on the system accordingly.
https://www.ptc.com/en/support/article/CS293793
Mohit
MRohillaCommunity ManagerAnswer
Support
Mohit
