Kepware Server Limitations - Rockwell
Kepware dooesnt allow for logical/logical non-blocking protocols for rockwell PLCs, when accessing Program tags. This means that if an OPC client needs to access program tags, the PLC needs to be setup with Symbolic addressing, which really slows down the R/W rates on the Kepware OPC UA server.
Anyone faced this issue?
Greetings ​@Yvster,
I hope this message finds you well.
Could you please confirm which firmware version you are currently using?
Yvster4-ParticipantAuthor
It is Kepware Server 7.0.236
I am asking about the PLC firmware version.
