Kepware server v7
Kepware server 7 comes with Audit Trail.
The Min days to preserver max limit is 90 days.
Details on this in the help menu is very vague.
Is it fully 21CFR part 11 compliant, if it only preserves for 90 days?
What is the recommended method to preserve audit log files indefinitely?
and also allow for an audit log report to be generated.
MKhatriAnswer
Support
Greeting!
Please take a look at the following article as it may help resolve your issue:
https://www.ptc.com/en/support/article/CS403270
https://www.ptc.com/en/support/article/CS459603
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
Mohit
MKhatriCommunity ManagerAnswer
Support
Greeting!
Mohit
