Kepware Tag not connected
External email from: Anderson_Perry_6@cat.com
I am able to generate the tags and everything looks correct but they will not read the values.  I am using an Allen-Bradley 1769-L16ER-BB1B Compact Logix controller
KCorriganAnswer
Hello Perry,
Please look at the below article as it is specifically regarding Allen-Bradley firmware v20.19:
https://www.ptc.com/en/support/article?n=CS277918
BRgds,
KC
Hello Perry,
What version of KEPServerEX are you using? What version of firmware is the device running? Can you not read any of the automatically generated tags or just some of them? When trying to read the tags, so you recieve any errors in the KEPServerEX event log? If so, please let me know which errors.
Thank you,
KC
anderp61-VisitorAuthor
Version 6.4 and firmware 20.19  I cannot read any of the tags
Unable to read tag
Also the tags a set for read/write external
KCorrigan14-AlexandriteAnswer
Hello Perry,
BRgds,
KC
