Kepware to 2 different PLC
Is it possible to use a Kepserver as a gateway/proxy between fx. a Beckhoff PLC and a Rockwell PLC?
Bhupendra
BhupendraAnswer
Yes, we can use Kepware as a Gateway b/w two PLCs for linking the tags by using the respective communication driver and Advanced tag plug-in
I request that you open a Support case with the Kepware technical support team for further steps and guidance.
https://my.kepware.com/s
Bhupendra
Bhupendra14-AlexandriteAnswer
