Link Excel with siemens PLC
Dear Sir,
               I want to Copy a column in excel sheet with 1000 cell value to Siemens S7 1500(Excel =>  Kepserver Ex(DDE) => Siemens PLC ).the only way up till now for me i write 1000 tags 3 time manually one time to define Siemens PLC tags ,second time in DDE, third time define in advanced tags .
so there's any way to assign 1000 tags for example as array or any way?.
Best Regards,
Ahmed Helmy
@ah_01_10783784
Unfortunately, I do not see a way to update the three applications without maintaining each individually. If you would like to put in an enhancement request, you can follow instruction provided in the following link.:
Article - CS295047 - How to open an Enhancement Request for PTC Kepware Products
The article can be accessed by using your My Kepware login credentials.
*Chris
