Local tag to receive Link Advanded tag
I would like to create local tags to receive the output of Link Advanded tags.
The purpose is to synchronize the timestamp of several data with a trigger.
I did it with Derived tags - Trigger but when the valueof a tag doesn't change, the derived tag is not updated with the trigger occurs. So my OPC Client doesn't see the new event.
Thanks in advance.
@JD_10173581,
At present there is no way to combine triggers with Link Tags. The only options are "On Data Change" or 'On Interval" I recommend opening a support ticket with the Kepware team so that they can analyze your specific needs and potentially come up with a solution. Here is a link to the login page where support ticket can be opened:
Log In | My Kepware
*Chris
