Logging DTL with OPC UA
I have a PLC program which send the DTL from the PLC, although I can log the timestamp based on the SQL side, is there anyway to log DTL directly from PLC to Kepware with the new/upcomming updates ?
MRohillaAnswer
Support
Greetings,
Sounds like Siemens.  DT (Date and Time) is supported, but I believe DTL (Date and Time Long) is still not.  I also believe this is true for Siemens TCP as well as Siemens S7 Plus. The workaround would be to switch the data type in the PLC to DT.
Mohit
Support
Greetings,
Could you please share the PLC model details with us?
Mohit
I have problem when try to log the DTL data from PLC 1211DC and also 1511PN, both with the newest firmware
MRohillaCommunity ManagerAnswer
Support
Greetings,
Mohit
