logging vlaues of a property
I have a property whose values are coming from kepserver(datas are simulated with sine function). I want to log those data for every one second. How to do this?
I have checked in the logged check box in properties, and in advanced settings, i have given Always as a data change type. Bu,t when i execute the "query named property history" service for last one minute it is taking 5 minutes delay to give the result and it is showing the values logged in milliseconds instead of seconds.
PaiChungAnswer
22-Sapphire I
In your situation the best way to get a recording very second is to set that on the Kepware side.
The channel should feature a 'scan rate' which you can set to I think 1000 (milliseconds)
If you are transmitting every millisecond right now, then you are probably overloading the platform which might be causing the slow response.
raluca_edu
But how often the data are coming from Kepserver?
Raluca Edu
PaiChung22-Sapphire IAnswer
22-Sapphire I
Sruthi15-MoonstoneAuthor
yes, the  scan rate of the tag was in 100. I changed it to 1000. Thanks for the reply
