3-Newcomer
MItsubishi Ethernet, Kepserver
When communicating with Mitsubishi PLC via Mitsubishi Ethernet from kepServer, I wonder if it is difficult to link if they are on different networks.
I have already confirmed that linking is possible on the same network.
Translated the topic from Korean to English using google translate.
Body - kepServer에서 Mitsubishi Ethernet을 통해 Mitsubishi PLC와 통신할 때 다른 네트워크에 있으면 연동이 어려운지 궁금합니다.
같은 네트워크에서 연동이 가능하다는 것은 이미 확인했습니다.
-By Community Moderation Team.
@NN_10627449
Multi-level networking will work as outlined in the page in manual provided in the following link:
https://ptc-p-001.sitecorecontenthub.cloud/api/public/content/87ac031549d746adbbd8b2590ebfe1a1?v=814255d4#page=16.
I also recommend opening a support ticket with the Kepware team to assist with analyzing your specific architecture.
*Chris
3-Newcomer
Thank you for your response.
I checked the contents of the link you sent me.
But what I wanted to know was the approach in a completely different network.
@NN_10627449
In the example on page 16, you can see that PLC 3 serves as a relay device connecting two networks. Is this not what you are describing?
Are you wanting to attempt the connection without the relay device? This cannot be done through KEPServerEX. I think you would benefit from opening a case with the Kepware team to get a complete look at your potential set up. Here is a link to the login page where a ticket can be submitted:
Log In | My Kepware
*Chris
