Need to connnect Postgres DB with KepwareEX
i have installed Kepware EX demo . I am planning to connect Postgres Db with Kepware to store the data in DB.
can anyone help me out with the steps in connecting Postgres DB with Kepware .
ntripathiAnswer
Greetings @AM_11504626 ,
Sure, I can help you with that! Please refer to the article CS277795 and follow the steps to connect Kepware EX with a PostgreSQL database:
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
ntripathi16-PearlAnswer
Thanks for your support.
For Postgres DB do i need to install separate ODBC drive?
if yes can you tell me from where can i install?
Yes, you will need to install a separate 32-bit vendor driver for PostgreSQL.
It can be downloaded from the below link:-
psqlodbc - PostgreSQL ODBC driver
