Aug 14, 2017 5:23 AM UTC
No longer be able to receive data from KEPServerEx when changing property from read only to read/write
By default,when binding data with remote thing from KEPServerEx, the binded property is read only. And I can see data coming in. But when I changed this property to read/write mode, It no longer be able to receive data any more. Even I rebind it, there is no new data received.
Anyone can help?
Thanks & Best Regards
Tom
AnnaAnAnswer
Aug 17, 2017 7:43 AM UTC
Hi Tom,
Indeed I had the same issue per my test locally.
I will open a Jira to R&D to confirm if this is an bug or configuration issue.
I will open a new case for this case to track the Jira progress.
I will contact you through the case thread.
So we could close this thread now.
Br,
Anna
Aug 14, 2017 6:11 AM UTC
Hi Tom,
Did you try to change Read-Only to Read/Write on ThingWorx Thing Property or from Kepware itself? Make sure that you have configured Read/Write properly in the Kepware side and try again.
Br,
Anna
weli13-AquamarineAuthor
Aug 14, 2017 6:38 AM UTC
Hi Anna,
Thanks for your help.I changed the status of property inside Thingworx composer. I just tried to change it in the Kepware side, but after selecting read/write, and hitting OK buttion,it changed back to read only.
Aug 14, 2017 9:58 AM UTC
Hi Tom,
Yes I had the similar issue. It's ok when playing with the self created New Tags, it only keep Read-Only for the existing Tags and cannot be changed to Read/Write.
Continue do further investigation and will let you know.
Br,
Anna
