ODBC > Link > SIM showing negative values at times.
KEPServerEX 6.15
V6.15.132.0
I have multiple ODBC values that show correctly in quick client but the sim tags they are linked to keep changing to negative values. The SIM tags will eventually show correctly but this behavior isn't expectable for my use case. For the life of me I cannot figure out what's going on here..2024-03-01_08-19-20.png
Could you please check whether the memory bit of the Sim tag is overlapping with another tag? In such cases, a turning bit in another tag can result in a different value (as in your case, a negative value).
If you believe there is no overlapping, I recommend opening a support ticket. Our technical support engineers will analyze the application report.
Best regards,
