pshashipreetham
PDF transfer from KEPServerEX to thingworx
There is use case were File Transfer Need to be done between KepServerEX to Thingworx in the OPC UA. How can it be done ?
@paic @c_lowy @CarlesColl @slangley @VladimirN
Thanks.
There is an article here - "How to send data from one KEPserverEX/ThingWorx Industrial Connectivity instance to multiple ThingWorx instances": https://www.ptc.com/en/support/article/CS293840
pshashipreetham
Hi @VladimirN ,
The post is about sending the PDF through kepserverEx on OpcUA protocol not sending the data from KepServerEx to Thingworx !
Thanks.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
