3-Newcomer
Periodic backup of KepServerEX project V5.21
Good afternoon.
KepServerEX V5.21
I would like to implement a periodic backup of the runtime project: is there a method to do this via the command line by running a batch script or using API calls?
Regards
Paolo
MKhatriAnswer
Support
Thank you for reaching out regarding the possibility of performing periodic backups in Kepware. Unfortunately, Kepware does not have a built-in feature for this specific function. However, users can utilize their preferred backup engine to extract the default.opf file from the ProgramData directory for backup purposes.
Users also have the option to create a custom batch script to facilitate the file copying process. Please let us know if you require any assistance or further clarification on this matter.
Thank you for your understanding.
Mohit
MKhatriCommunity ManagerAnswer
Support
Mohit
PP_KW53-NewcomerAuthor
3-Newcomer
Hi Mohit, thanks for your reply, we will follow your advice.
Have a nice day.
Paolo
