Python Async OPC UA to Kepserver, which driver to use?
I have a python code that reads data from excel and sends to kepware, I am trying to set this up and setup the tags in kepware as a server, and the python as a client. This will eventually be connected to a DeltaV system which is another client, but for now I want to test my code sending data into Kepware.
Which drivers should I use for this purpose?
AKsharaAnswer
Thank you for the post. Based on the setup you’ve described, the Memory Based Driver would be the most suitable option. Since this driver requires a licensed component, access depends on your current package.
If you already have the Manufacturing Suite, you should be fully equipped to implement this configuration.
Please let us know if the Memory Based Driver is not included in your license, and we will connect you with our sales team to explore available options.
-Thank You
Kepware Support Team
AKshara14-AlexandriteAnswer
-Thank You
is that on OPC UA or OPC DA? which other suite would have it? is there a away I can test it before actually buying the suite?
