Queries regarding Kepware IoTGateway
I am new to Kepware, I want to configure IoT Gateway to send all the data to external REST end point listening on Splunk to collect the data. However i have configured IoT gateway, hence i think i am missing some steps here,please help me with following queries,
Does IoT Gateway requires additional license ?
How do we validate data started sending from IoTGateway?
I have received the following in log, does it mean that its connected and sending data ?
Date Time Level Source Event
7/22/2019 12:02:15 PM Information KEPServerEX\IoT Gateway IoT Gateway using JRE at [C:\Program Files (x86)\Java\jre1.8.0_221].
7/22/2019 12:02:16 PM Information KEPServerEX\IoT Gateway Running with Java 1.8.0_221 [Oracle Corporation Java HotSpot(TM) Client VM version 25.221-b11].
7/22/2019 12:02:22 PM Information IoT Gateway Connection restored to server: '127.0.0.1:57212'. Reinitializing server configuration.
7/22/2019 12:38:58 PM Warning Licensing Feature IoT Gateway is time limited and will expire at 7/22/2019 2:38 PM.
7/22/2019 12:39:10 PM Information KEPServerEX\Runtime REST client 'Kepsplunk' started publishing to 'http://splunkpoc.eastus.cloudapp.azure.com:8088/services/collector/raw'.
7/22/2019 1:30:00 PM Warning Licensing Feature IoT Gateway is time limited and will expire at 7/22/2019 2:38 PM.
7/22/2019 2:30:00 PM Warning Licensing Feature IoT Gateway is time limited and will expire at 7/22/2019 2:38 PM.
7/22/2019 2:38:59 PM Warning Licensing Time limited usage period on feature IoT Gateway has expired.
7/22/2019 2:39:00 PM Information KEPServerEX\IoT Gateway IoT Gateway service stopping.
Do we have any log in kepware which shows data is sending from IoTGateway?
What would be the best practice to send all the data collected at Kepware to external application which can receive on REST?
Please suggest me on the above. Many thanks...!!
